Ok I will try, I will keep you posted in case others have same problem.
One last thing, next week probably I’m getting my wireless charging pad (original), do you happen to know which zone in the bsi where it resides?
I have a friend (same guy with his 5008) who has the wireless charger in his car, so my plan is to connect to his car and read his zone in the bsi and then write the value in my bsi to activate it.
Thanks to all participared on reverse engineering of communication. You have done great job. I was able to upgrade my Peugeot 5008 with RCC and CIROCCO without LVDS connector into NAC wave 2 system with reverse camera, CIROCCO with navigation data and retrofit of wireless charger. All else has been more or less discussed about here, but retrofitting the wireless charger and exact miledge of CIROCCO.
Reading miledge of CIROCCO is as discussed here. Clarification: the four numbers and inverse numbers read from eprom are app. the reading of odometer in 100 meters. I wasn't able to write the eprom while it was connected to CIROCCO, but this seems to be common problem with my prommer.
In order to retrofit the original wireless charger, You need the charger element and coding for BSI. All else, including wiring, is ready on vehicle. In my case activation in BSI-2010-EV needed reading the current value of wireless charger status (00 in my case) and changing it (to 01 in my case).
Reading the current value:
>752:652
1003
222437
Writing the new value and booting BSI
>752:652
:B4E0:03:03
2E243701
1103
All this is well documented, thanks to all people involved. It is rare people share their work this open. I hope I can do something in return.
Reactions: Francesco Ratta
Try "0x1F", should work for 5008.
Added calib:
Added config:
Quick update, “0x1F” did the trick for the correct 5008 images in the settings. :)
Since I felt that the camera may have been wrong, I took the 212A values from the new 5008 config file and uploaded to the nac using Vlud’s recent discovered method on clearing the cache for the nac. To my surprise the camera looks the same, so I guess that there isn’t any difference between the 3008 and 5008 camera settings, at least on this restyle configs.
I will keep you updated wether the new 3008 calibration fixes the echo problem.
Good evening everyone. :)
I think the camera might still be wrong even with the latest 5008 restyle config for 10”.
Here I have 2 pictures, one from the old screen and one from the new. It’s clear to see that before I was able to see more of my rear bumper.
Does it look correct to you the new image, or maybe the old image was wrong back then?
EDIT:
I think you are meant to see more of the rear bumper.
Here is a video test of rear camera on 3008/5008 from 2021:
Pièces jointes
    190.2 Ko · Affichages: 59
    233.5 Ko · Affichages: 61
You should see a small part of the bumper (the red line should be at +/- 30cm from your bumper), if you don't: the image is not correct
Then my image is wrong.
I remember somebody posting a picture with some guidelines on how to measure the correct values, I don’t remember if it was in this thread.
In all videos I see on YouTube the bumper is visible, so definitely the image must be wrong.
I think I will try to load my old 5008 config and make note of the values roll pitch yaw, as these must be the ones related to it.
The X, Y, Z axis I believe are for the image projection on the display.
Shouldn’t the 212A from the restyle config file be correct? It seems weird to me.
  • v1.2.7 - 13/12/2021: Sound adjustment for AAS in 2100, 2132 zone support, new values for menus in 2127, clearer 212A zone values, fix various settings names & values
La mise à jour du logiciel n’a rien à voir avec les fonctions du NAC
-> Tu pourras activer l’option, mais elle ne marchera probablement pas
Just like rule and a few others here I am thinking por getting a 3008 panel to install on my C4L B7 but I just have a few questions before.
I dont have RT6/SMEG/NAC, only a chinese android unit that serves me well and I will be keeping it.
From the panel I would need to disable a few features that I wont be using like lane assist, start/stop, etc
I already have an arduino nano + MCP2515 that I used to program my MATT2010 with Infizer's software.
1) Do I need to get a Can-shield or my current setup will be able to program/calibrate the 3008 just fine? (I imagine that I would need to upload the new sketch to the arduino and check if the pins that are connected to the MCP2515 are the same)
2) I need to first connect the 3008 to the car and then connect arduino via ODB2 port (and to PC) to program it or I can connect the 3008 panel directly to my computers with arduino?
3) If is possible to connect directy to the screen does anyone have the pinout of 3008 so I can get the Can High, Low and 12V/ground ?
Thanks for the help!
Hi. O applied the icockpit on my 308. Have the NAC already with dual.lvds, One conected to screen and other to icockpit. Working fine after changing the pinout of the icockpit cable.
One thing im missing is the ability to Change themes on.the icockpit. I can Change ONLY the colora via the NAC, but no full.themes.
Can i program any button with the Arduino to act like the One on the 3008 on the steering wheel that changes the dials, etc?
I have a 2012 508 RXH HYbrid4 with RT6 + JBL and BTA (Peugeot SOS).
Can I use the original BTA, or do I have to get the newer version if I want to use connected services?
Does the new BTA 2.0 support the original SOS and PEUGEOT buttons of the 508?
Can I directly connect a rear parking camera to the NAC if I didn't have one before?
Can I connect a front camera?
Are the AliExpress SMEG to NAC cables suitable for RT6 to NAC conversion?
I appologize in advance, if the questions have already been asked, I did not manage to find an answer.
FR (Google translate):
J'ai une 508 RXH HYbrid4 de 2012 avec RT6 + JBL et BTA (Peugeot SOS).
Puis-je utiliser le BTA d'origine ou dois-je me procurer la nouvelle version si je veux utiliser les services connectés ?
Le nouveau BTA 2.0 supporte-t-il les boutons SOS et PEUGEOT originaux de la 508 ?
Puis-je connecter directement une caméra de stationnement arrière au NAC si je n'en avais pas auparavant ?
Puis-je connecter une caméra avant ?
Les câbles AliExpress SMEG vers NAC sont-ils adaptés à la conversion RT6 vers NAC ?
Je m'excuse par avance, si les questions ont déjà été posées, je n'ai pas réussi à trouver de réponse.
[QUOTE = "VLud, post: 2625688, member: 108646"] This type of card is perfectly compatible and working, you just have to change the source code to 8Mhz and control soldering points because it can be quite bad (it is only a 1 $ card on Aliexpress so ..)
[/QUOTE]
Thanks, I was wondering about that, If I was going to be able to just use my setup
Only thing I need is to JUMP the J1 on the MCP2515 board I think
But seeing your picture, it doesnt seem to be with any Jumper so perhaps not needed the 120ohm resistor?
Hello Guys. I recently bought a NAC WAVE2 to replace my RCC unit on my 3008 Griffe Pack in Brazil. everything was working great till the dealership scanned the NAC so I lost eh access to the amplify options, the tochbutton disapered from the screen and looks like that now, the place I did the circle usually has the acess to the amplify menu and trip computer. There is a way to recover it?upload_2021-12-15_10-13-3.jpeg
Reactions: mmcorrea
Hello Guys. I recently bought a NAC WAVE2 to replace my RCC unit on my 3008 Griffe Pack in Brazil. everything was working great till the dealership scanned the NAC so I lost eh access to the amplify options, the tochbutton disapered from the screen and looks like that now, the place I did the circle usually has the acess to the amplify menu and trip computer. There is a way to recover it?Voir la pièce jointe 24498
Using the software tool for the nac, with the arduino kit you can re-enable the amplify menu and trip computer.
Hello everyone.
I have a 508 RXH HYbrid4 from 2012 with RT6 + JBL and BTA (Peugeot SOS).
Can I use the original BTA, or do I have to take the new version, if I want to use connected services?
Does the new BTA 2.0 support the original 508 SOS and PEUGEOT buttons?
Can I directly connect a rear parking camera to the BTA if I did not have one before?
Are AliExpress SMEG to NAC cables suitable for RT6 to NAC conversion?
I apologize in advance, if the questions have already been asked, I have not been able to find an answer.
Hi, I can answer a few of your questions:
“Can I use the original BTA, or do I have to get the newer version if I want to use connected services?”
- Connected services are bound to the donor VIN and BSI, so unless your radio is brand new, there’s no way to activate connected services, unless you change BSI temporarily to donor VIN.
“Can I directly connect a rear parking camera to the BTA if I did not have one before?”
- Yes, it’s possible, there’s plenty of forum threads explaining how to with schematics too.
You will need to figure out which camera adapter frame you will need for your model, I only know the ones for 3008/5008, but I am not sure if the 508 uses the same. I suggest you to pay for an hour access and check on servicebox.
“Can I connect a front camera?”
- Front camera can be connected too, it requires a separate ECU (visiopark 2) where both the front and back camera connects.
I read it, thank you.
I fear the front camera might not work with the 508, because despite being with a BSI 2010, it does not have the 360 degree camera option anywhere in the BSI configurations.
Je l'ai lu, merci.
Je crains que la caméra frontale ne fonctionne pas avec la 508 phase 1, car bien qu'elle soit équipée d'un BSI 2010, elle ne dispose pas de l'option de caméra à 360 degrés dans les configurations BSI.
Yes, I believe so.
I downloaded DiagBOX from ServiceBOX and upgraded to 9.118 - all legal, logged and working with my XS EVOLUTION cable.
I just have to buy some tokens and update every computer.
HCU1 and HCU2, DCM3.5 HY, etc, so I will update the BSI as well.
Bonjour à tous, et encore un grand merci à tous ceux qui s'impliquent dans le forum . Je suis en train s'adapter un i-cockpit de 3008 dans une 508 de 2012 , j'ai beau avoir chercher dans tous les sujets je n'ai pas trouvé le calibrage cirocco pour 508 de 2012 (hybride) , l'auriez vous ? merci encore.
