@jeery2212 @Alcor72 : par curiosité vos adaptateurs ont le loquet de verrouillage noir ou gris/blanc ?
em bsi2010 não EV eu fiz isso.
https://www.drive2.ru/l/597886936467655241/
my version of diagbox only displayed one of the two encodings. I don't remember the section.Obrigado @pepelxl, I am connected using diagbox, do you know in which section on BSI I need to change those informations?
Ah oui... Ceux qui sont normalement mieux finis... Ca fait peur !il était gris , il s’est cassé quand je l’ai fermé![]()
Good job! did you manage to integrate the led indicators to the display(service, airbag and stop?
Great job, Hopefully I will do the same soon on my DS4.
Did you do a 3d print for the frame? Have some picture? (or a 3d model?)
Like @Andy13 ask, did you put the led service indicator?
Also I suppose you put button on the dashboard for service/backlight dimmer?
Update: It seems that not all units which appear as RCC_A2 in the engineering mode are capable of mirror screen.Hello everyone!
Today I have tried the software on my Citroen C3 Aircross with cheap CAN bus module (8 MHz). Works great.
Congrats for the hard work.
I tried to activate Android Auto, icon appeared in the menu but unfortunately doesn't work.
The current version of the system software is 092B. Probably it's an RCC A1 or some other limitation.
In the engineering mode I have: AARS_PSA_RCC_A2_DAB_190226
Calibration number: 942741.
Any thoughts are welcomed.
Merci beaucoup!
What material did you use to print? (I was thinking using black abs)
Does the print was in 2 times? (right half then left half)
How does it fit on the dashboard or cirocco lcd? (Metallic pin like OEM cluster) or is it just pushed?
If you have some picture of the back I am interested :Yes:
Unfortunately I dont speak French but I have been using google translate to help read the posts for the last 2 days.>752:652
:E4D8:03:03 (also :B4E0:03:03 and :C318:03:03)
OK
5003
7F2722
7F2722
OK
5003
7F2722
5003
7F2722
Hello,
This is a great threadUnfortunately I dont speak French but I have been using google translate to help read the posts for the last 2 days.
I have a problem with 2018 Peugeot 2008 continental NAC EUR Wave2 unit, the screen is frozen on Peugeot logo at start up, the radio station still plays in the background but i cant search for stations or do anything else? I tried to update firmware from usb pen-drive with soft downloaded from Peugeot main site but it does nothing just stays on the logo screen,
I have 2 questions ,
no1: is there a way to force the firmware upgrade with or without arduino or if no way is possible,
no2: is it simply a case of download and save the parameters from the 2008 wave2 unit and upload into another replacement wave2 unit (but replacement is from a 2019 308 model not 2008 model? with same part number 9821908980
I can read the parameters with arduino from the 2008 nac wave2 unit even though it is stuck on the peugeot logo.
I'm new to this kind of programming but I have used diag box.
Thank you
62F0809664992380000D96649923800203FFFF0001FFFFFFFFWhat is the output of 22F080 and 22F0FE ?
62F0FE000000000DB317050C200179250D030FFD90D84202918198
Salut, j'ai le même problème, mon nac est posé depuis plus d'un an, j'ai ajouté le DAB lundi, et trifouiller dans la config car je trouve que le volume "baisse" tout seul (enfin bref). Après 5-6 essais de changement via l'outil, il reste sur le logo Peugeot.
j'ai tenté : débranche / rebranche batterie : NOK calibration 508 1 sw (wave2) NOK configuration 508 1 sw NOK, configuration backup : NOK, configuration d'origine (backup) de 308 : NOK.
C'est un nac d'origine 308 je crois, un hw19.
Je suis à sec d'idée![]()
You are right. Thank you very much!
Now I have another two questions.
1. Before NAC I had Android navigation with aftermarket reverse camera. Should NAC work with the same camera?
2. Is there a way to connect NAC to My Peugeot App? (Bluetooth coonected service)
Thank you!
Post here what you try to do with .calHi.
En. Unable to change and recalculate calibration from Peugeot 3008 with panel from DS4/C4B7/C4L
If you transfer the entire line from one calibration to another, the file is filled in at 99% and then hangs without trying to flash it into the block itself.
Who can help recalculate the total amount and explain how and what to count?
Ru. Не получается изменить и пересчитать калибровку от Пежо 3008 с панелью от DS4/C4B7/C4L
Если перенести целиком всю строку из одной калибровки в другую, файл заливается на 99% и далее висит без попытки прошить в сам блок.
Кто может помочь пересчитать общюю сумму и объяснить, как и чем считать ?
Hi. I have installed RCC A2 (9820250280) from C3 2016 on 308 T9 and there is a problem with setting up.
1. When I try to upload the calibration, nothing happens, the progress bar does not appear. I can only disconnect the arduino.
2. When trying to upload the configuration, with some files there is an error loading the field 2110 and it stops.
3. There is only English on the radio. After updating the software - PSA_rcc-firmware_1_076_16-1B116-4_RCC_EU_W2.tar - nothing changes. Firmware downloaded based on VIN from Citroen website.
4. The display illumination is very low and unresponsive to changes in the menu.
Thank you for your help.
