Byte 04 value 01How do i "code" electric driver seat welcome" option? I´ve seen this code 652 752 2E:234C:04:01 but don´t know how to code it with the arduino. Anny hints are welcome.
2E234C01
Would it be possible to describe all the steps on how to activate/program this option for someone who has never done this? I know how to connect the Arduino to start the diagnostic session, I know how to use the vlud program but as I don't have the electric driver seat welcome option, I would like to "program" it so that I can activate/deactivate it whenever I want. Does this then appear in the vlud program as a new zone or does it always have to be using the Arduino and the commands? Thank you very much.Byte 04 value 01
2E234C01
You need to do coding in BSI and NAC:Would it be possible to describe all the steps on how to activate/program this option for someone who has never done this? I know how to connect the Arduino to start the diagnostic session, I know how to use the vlud program but as I don't have the electric driver seat welcome option, I would like to "program" it so that I can activate/deactivate it whenever I want. Does this then appear in the vlud program as a new zone or does it always have to be using the Arduino and the commands? Thank you very much.
3008_P84E-9694131380.ulpWhat type of actualization you did?
is now black or in boot mode?3008_P84E-9694131380.ulp
why then you uploaded same sw you have inside?/
3008_P84E-9694131380.cal
No, the old software is not it, I forgot itwhy then you uploaded same sw you have inside?
if you din't delete .log files from folder should be here saved post it hereNo, the old software is not it, I forgot it
What model of unit did you have before? Try a calibration for Peugeot Expert and then configure the make and model with Arduino.Hello dear colleagues,
I wanted to activate Android Auto but it turned out that the unit I have only has carplay. So I bought a NAC wave 2 unit (from the set with touch buttons) and installed it under the display in my car. Using the VLud program, I added the VIN, uploaded the appropriate calibration and parameters for my car, activated Android auto but I can't find the button coding anywhere.
The touch display itself works, but the physical CAR, SETTINGS, NAVI, APPS, PHONE, MIUSIC buttons do not work, and the power button does not respond to volume changes and when pressed, the sound is muted instead of turning off the navigation. Please let me know how to recode the navigation step by step so that the buttons function properly ?
Regards
hi. you can send the last program pepelxl please . i dont found in gi
good morming my friend I want to use this programhi. you can send the last program pepelxl please . i dont found in github
good morming my friend I want to use this program PSA Coder by Pepelxl v0.1 But l couldn't the link help me pleasehi. you can send the last program pepelxl please . i dont found in github
Where did you find this program?good morming my friend I want to use this program PSA Coder by Pepebd v0.1 help me please
Hi,What model of unit did you have before? Try a calibration for Peugeot Expert and then configure the make and model with Arduino.
The control of the physical buttons is in the calibration that you load into the unit. It is not possible to change it with the program and arduino. It is possible that no calibration you put on your nac wave 2 will work since the previous unit was nac wave 1. The only solution I see is for someone who knows from the forum to tell you how to modify the fmux lines of a nac wave 2 calibration so that works with your car.Hi,
Previously I had the unit visible in the attachment. I tried calibration (proace, expert) and parameters for these cars. I don't see the option to change buttons anywhere in the Arduino program.
@VLud Can you help me, please ?Hello,
I changed RCC Wave3 A1 for RCC Wave3 A2 in my Citroen C3 Aircross.
I can make coding and editing of parameter without problem, but I can't load calibration on my new unit.
I trying to load many different calibrations, but I have problem of stalling. I have frames without answer. Some times at 2, some times at 6...
My configuration is Arduino Uno R3 + Can board little with MCP2515. I have jumper on 120ohm resistor on the board (Already tried without resistor too).
Already have jump wire between OBD GND (pin 4+5) to Arduino GND.
New RCC hardware is 9833500080.
Attacched some log files.
Can someone help me, please ?
Thank you![]()
I have no, no communication from canif you din't delete .log files from folder should be here saved post it here
Do you mean turning OFF the rear position lights during the day along with the DLR?Yes.
Option to disable DRL.
YesDo you mean turning OFF the rear position lights during the day along with the DLR?
Is there anyone on the forum who knows how to reprogram these lines? Because at the moment I have a unit that cannot be used without buttonsThe control of the physical buttons is in the calibration that you load into the unit. It is not possible to change it with the program and arduino. It is possible that no calibration you put on your nac wave 2 will work since the previous unit was nac wave 1. The only solution I see is for someone who knows from the forum to tell you how to modify the fmux lines of a nac wave 2 calibration so that works with your car.
If I'm wrong, let @VLud or @marcins correct me.
I will be very grateful for your help. RegardsDo you remember zone ID? Is this 23FF? And option for OFF is 00?
For DRL
>752:652
1003
:B4E0:03:03
2E23B001
2E2901FD000000010101
1001
I didn't change anything in 23FF zone.Do you remember zone ID? Is this 23FF? And option for OFF is 00?
Or as you wrote?
Have you found anything regarding the new gear lever?Ce que je cherche , c'est activer les nouveaux menus de selection de vitesses...
