Hello Everybody, I've been trying to follow the thread and read as much as possible (191 pages is wild 😮‍💨) but Im having a problem that I couldn't find any mention or this specific combination.
For context I have a Citroen C4L (C4 B7 sedan for LATAM) HDI. It has BSI2010, came with SMEG screen. I installed both CIROCCO from 3008 and NAC WAVE 4 HD 10" from DS3 Crossback.
- I tried at the beginning to install other calibration that I thought was for C4L but got black screen because it was for W4 SD. Then tried different calibrations and while changing between one and another, the physical button for the menus stopped working. They do work, the actuator testers in DiagBox show they register the pressing, but wont work with NAC W4 .
- The other problem Im facing is that I cant calibrate the camera (VP1 180°), I found calibration for W4 SD, but tried applying it and doing the steps @VLud indicated in Page 95 changing 012a to refresh cache, but dont seem to be applied because image is still the same Is there a different procedure for W4 HD ?
- Another issue is that when I use the wheel in the steering wheel for changing the mode in CIROCCO cluster, it also changes the brightness of the backlight of everything. I have installed the rheostat button from the cluster and changed in zone 2100 from Ambence to Rheostat. Should I change anything in NAC too? didnt find any related value. Perhaps in Diagbox? Anyone had this issue ?
Please I would really appreciate any kind of assistance with these issues, let me know what further info can I provide to give better context 😃
Use this: https://afululu.com/PSA/010E/ this picture show how you need to setup for C4/DS4
Pièces jointes
    16.5 Ko · Affichages: 108
Bonjour, est-ce que quelqu'un qui a activé les thèmes supplémentaires sur le peugeot 2008 nac peut me dire si le thème « Kryptonite » fonctionne correctement ou s'il pose des problèmes ? Et si oui, pouvez-vous joindre des photos ? Merci de votre compréhension
English:
At the moment I have 5 themes activated. Standard ones: RED, BLUE, QUARZ and two new ones COOPER, ELECTRO. Why did I choose these two additional ones? - because they are displayed not only on multimedia, but also on 3D icocpit. It looks harmonious and cool.
French:
J'ai actuellement cinq thèmes activés. Les thèmes standard : ROUGE, BLEU, QUARZ et deux nouveaux : COOPER et ÉLECTRO. Pourquoi ai-je choisi ces deux thèmes supplémentaires ? Parce qu'ils s'affichent non seulement sur les écrans multimédias, mais aussi sur les écrans 3D. Le résultat est harmonieux et original.
Icocpit Samples:
Pièces jointes
    457.4 Ko · Affichages: 65
    56.6 Ko · Affichages: 59
Codé enENUM
F7
CFG_EKY_BVA_UDS_LVPR_004_F7​
Levier de vitesses impulsionnel​
FB
CFG_EKY_BVA_UDS_LVPR_004_FB​
Selecteur de vitesse rotatif​
FD
CFG_EKY_BVA_UDS_LVPR_004_FD​
Joystick levier de vitesse​
EF
CFG_EKY_BVA_UDS_LVPR_004_EF​
Levier de vitesse e-Toogle​
FE
CFG_EKY_BVA_UDS_LVPR_004_FE​
Levier de commande de vitesses​
@marcins Is it necessary to recode the shift lever with DiagBox?
I changed the values according to what you indicated and activated it in BSI. It recognizes the shift lever, receives the information, but doesn't fully shift and stays in P for park.
I'm trying to replace the rotary shift lever on my Peugeot Rifter with the shift lever on my Peugeot 5008.
@marcins Est-il nécessaire de télécoder le levier impulsif avec diagbox ? .
Je change les valeurs selon ce que vous indiquez et je l'active dans BSI, il reconnaît le levier, il reçoit l'information mais il ne termine pas de faire le changement et reste en P pour le stationnement.
J'essaie de remplacer le levier de vitesses rotatif de ma Peugeot Rifer par le levier de vitesses impulsif d'une Peugeot 5008.
I did as you described but nothing changed. Any ideas what I do wrong?
Some details about my configuration:
7' SD, NAC VAWE4 HW: D4 W4_B4DAB_HW19
J'ai suivi votre description, mais rien n'a changé. Avez-vous une idée de ce que j'ai fait de mal?
Quelques détails sur ma configuration :
7' SD, NAC VAWE4 HW : D4 W4_B4DAB_HW19
Was: Était:
Now: Maintenant:
Issue SOLVED!
I used Lexia 3 + Diagbox. After repairing Visiopark everything looks and works fine now. I don't know why the 212A zone manipulation didn't work for me. So if anyone has the same problem, you can try to solve it using Diagbox.
Problème RÉSOLU !
J'ai utilisé Lexia 3 + Diagbox. Après avoir réparé Visiopark, tout fonctionne correctement. Je ne comprends pas pourquoi la manipulation de la zone 212A n'a pas fonctionné. Si quelqu'un rencontre le même problème, vous pouvez essayer de le résoudre avec Diagbox.
Issue SOLVED!
Problème RÉSOLU !
You did a calibration from Diagbox?
Yes and no :) First I set the parameters in 212A which are valid for my car and then I did a "repair", I don't remember what it named in Diagbox. As I understood it something like changing 01 to 00 to clear the cache, which didn't work with arduino for me.
It looks like in this image.
So you used a parking spot to fix the camera?
Yes, you are right. But I think that there will be more or less enough space that approximately meets the requirements for parking lines. The main thing is that the camera should sees the lines. Then you need to follow the instructions on the diagbox. The whole procedure takes about 5-15 minutes.
Reactions: ygorigor
Hello and wish you all a great day!
Firstly, big thanks to @VLud & @bagou91 for making this amazing tool, u`re the goats!
Hello sir, I have working pypsadiag installed on my PC. My car is 2022 508 GT selection 1.5 Bluehdi EAT8.
I managed to activate color themes in the NAC.
Can you help me to activate everything you activated in your car? Grip control , city parking. Other stuff you posted pictures of?
Can someone help me activate the themes on cirocco?
If I try to activate them in the 0900 area it doesn't let me do anything.
Hi friends,
I have a Peugeot 508 SW (2020) with Visiopark 1 factory installed in the vehicle.
I want to install Visiopark 2.
I purchased a front camera and module 9835208080 from a Peugeot 508.
I have the installation diagrams.
Can anyone who has installed it tell me the parameters I need to modify with PSA-Arduino-NAC?
Do I need to modify any parameters in BSI?
Thank you.
Hi friends,
Thank you.
Hi
Here you can find some info.
It's for 3008, but you can grab some ideas from there.
You can use translation from German language.
Reactions: jrgbel
I managed to activate these functions with pypsadiag.
But somewhere along the way my rearview camera got a little weird. How do i get the "car image" back?
Pièces jointes
    195.3 Ko · Affichages: 84
    251.6 Ko · Affichages: 83
Bonjour! dites-moi, quelqu'un a eu cela dans pypsadiag? toutes les zones lisent bien, mais pendant la lecture, BSI se bloque et n'a le temps de lire que VIN. sur un autre ordinateur portable, tout fonctionne... qu'est-ce qui ne va pas avec le mien?
Problem solved. Started a calibration process of 180 camera Via diagbox, eventhough it failed by the error code white lines, still fixed the missing car symbol on the camera.
Now second problem, when i change the song through the encoder on the steering wheel while a menu page open in nac screen other than music, it displays the song Info in the middle of the screen with a big popup box. It was displayin the Same information with drop down ribbon from the top before. How do i fix it?
Nobody seems to care for an answer. Can anyone please share 2021-22 GT Selection 1.5Bluehdi EAT8 Full BSI and NAC backup?
And i also need 9693637680 calibration
Does anyone know if the rear camera view can be accessed through NAC while not in reverse gear (in a car without a physical camera button)?
I've seen on some cars with visiopark 2 that there's a menu item in NAC called " Visual parking assistance" which allows you to bring it up, but I only have visiopark 1 and I can't see any telecoding options in NAC that could fix it .
I suspect it could be somewhere in the first byte in zone 2105 as there's a parameter there called "Touch button Position \"Front Camera\" , but I've tried changing it and other spare bits to no effect .
Another possibility is that only cars with visiopark 2 have this option in the menu?
Thanks
Thanks
or 360view
Hello. I'm trying to unlock the semi-automatic parking on a Citroen C4 Cactus (F3). I have a problem with coding the DAE unit. Here is the log of communication with it.
>6B5:695
OK
81
C1D08F
21A0
61A003FAFB0A02000001
82
C2
In all the examples I've seen, it returns a packet like
61A005C0ХХ0002000001 - where XX is the configuration byte (CC or DD), but the first two bytes are always 05C0, and my unit returns 03FA....
When writing zone A0, the following packet is used 34A00000000605ХХ... - where 05 is the Id Tlc Dae.
05 -Id Tlc Dae is taken from the response 61A005C0XX, or is it a coincidence?
When trying to write zone A0 with key 2305, it gives an error of an incorrect key. From which I conclude that my block is not DAE_BVH2. The block does not respond to requests via the UDS protocol.
Maybe someone has encountered this?
Hello. I'm trying to unlock the semi-automatic parking on a Citroen C4 Cactus (F3). I have a problem with coding the DAE unit. Here is the log 34A00000000603FC00020000CF22of communication with it.
>6B5:695
OK
81
C1D08F
21A0
82
C2
34A00000000603FC00020000CF22 You can Test it
When trying to write FC gives an error 7F3422. When writing 34A00000000603FA000200005719 or 34A00000000603FA0A020000F9C5, the value changes to FA, diagbox displays that the power steering with the function of semi-automatic parking and start stop. But when trying to park, the screen says "Release the steering wheel". What am I doing wrong?
BSI
Zone 2300
13
to
77
AAS_UDS_G6 (cal ref. 96 940 666 80)
Zone 2101
0907B307880502
to
0907B30788050A
DAE? (cal ref. 96.930.929.80. ECU key CB0F)
Zone A0
03FAFB0A02000001
to
03FAFA0A0200000x
NAC
Zone 210C
0010
to
C010
Pièces jointes
    981.1 Ko · Affichages: 54
    422.2 Ko · Affichages: 52
