Hello, I have a citroen c5 x7, 2013 that already had a smegIV installed, I have followed the steps and I have an arduino and 2 can shield installed to go from can 2004 to 2010, should I use that same calibration for my car? I have problems with some of the buttons on the steering wheel that do not appear in the steering wheel configuration settings, as well as the comfort equipment, safety, etc. Thank you for your help.Thank you both for the fixes!
After changing the time to 2000 on the sketch i was able to read the parameters of Bosch RCC but not able yet to change any parameter or upload new calibration. I will take it from my car and provide better information.
AIO now displays the "telecoding session" screen using the software but hangs and do nothing then.
Log output:
Code:> 00 < 7F0022 > 10C0 < 50C0
I also want to share this file to the database: Citroën C5 Chine for RCC/NAC_CN
Citroen_C5_CHINE_9692911680.CAL : https://drive.google.com/file/d/1Ap-NeWvPpiTTkKbGENlF0j2EmiN_HOaB/view?usp=sharing
Sorry I have not explained myself well now I try to go from smegiV to Nac, I already have everything working in NAC but I have problems with adjustments in steering wheel keys that do not work and the security menus etc, appear empty. I already have clock, language change and speedometer on-screen navigation aid.You cannot do any kind of configuration to SMEG_PLUS using the application of this topic.
Altough is not related here, for C5 you should use a SMEG+IV2 unit coming from a DS3, or C3 (CAN2004 cars) for better compatibility and you will not need to use the CAN2004-2010 adapter anymore.
I was informing Horuscursino that my question was not directed to the smegiv installation but to a Nac, hoping that, if it has a C5, it can tell me if it has an adapted file to make it work, already modified. Thank you.But this has nothing to do with the current subject, no need to spam 3 different topics with the same message you won't get more answers
So, would it also be necessary to know how to programm when I found out those button references? I do not have that knowledge, I think i will have to wait until someone with this knowledge has done it on a C5 and is willing to show it. Is it so, that the calibration used by the other C5 in this forum is NOT the solution? ThanksC5 X7 production stopped in 2017 worldwide so the last fully compatible radio for it is the SMEG_PLUS. The production continued on China and it received newer units but using different steering wheel with less buttons. NAC and RCC (and AIO LATAM) were not planned to be controlled by a MENU button so they developed a button for each menu which X7 does not have. Another keys does not work due to simple incompatibility. No other steering wheel configuration for NAC/RCC works fully or close to all functions. The same concept applies to the car configuration. When you understand there is a production difference then you need to accept your situation and continue to use the radio without the functions (like i did).
If you has C knowledge you can tweak by yourself the main sketch of conversion and forward original keys to some other.
Le com doit être libre = fermer l’IDE Arduino quand tu te connectes sur le logiciel avec l’interface.
Le reste est OK
Brackets for 3008 Cirocco to mount into 208 oem mounting points, frame need some trimming to fit as is very limited space , brackets need to be glued with epoxy https://www.thingiverse.com/thing:4774526
Voir la pièce jointe 19489 Voir la pièce jointe 19490 Voir la pièce jointe 19491
Good Job. TankyouBrackets for 3008 Cirocco to mount into 208 oem mounting points, frame need some trimming to fit as is very limited space , brackets need to be glued with epoxy https://www.thingiverse.com/thing:4774526
how to restore NAC Wave4 after failed calibration О_о
is seen by the program version 1.0.3
как восстановить NAC Wave4 после неудачной калибровки О_о
видится прогой версией 1.0.3
j ai bien rentré les ponctuations
