Pinout disponible dans le tutoriel pour passer au NAC à partir d'un SMEG+salut tout le monde je veux brancher un ampli sur ma voiture mais je ne sais pas ce que sont les PINOUT du NAC
Merci .
Merci .
Hi RicardoThey won´t fit without cutting the dashboard
I fit it, u have to cut dashboardHi Ricardo
Did you fit your cirocco dashboard to 508 I?
Hallo/Hello,@VLud Entschuldigung für das Kopieren des falschen Felds in der Übersetzung Hallo nochmal, ich habe den Sportmodus auf meinem Auto aktiviert, aber wie ist die dynamische Anzeige ? aktiviert? Leistung, Boost, Drehmomentanzeige?
I can take you a photos, but I was made it from old dash + epoxy polymer, if you need - tell, I will take pictures for you.Please can u help me with frame ? i pay,pleaseeee
Thanks Greate job ! Are you have more photo with fitting 3008/5008 cirroco to 508 I?I was do it ))
https://ibb.co/gJ3HK8w
Yes I enabled it myself, those are the zones of BSI:
Ps: the anti rising function is managed by the siren itself, you still need a proper MUS ecu compatibile with that function (if you read AS = anti soulèvement on the label). I’m not quite sure if the siren must have a proper software too, on my 208 I used the original ECU but I know for sure that mine doesn’t have the anti rising feature so I bought another one from a peugeot 508 to see if the function starts to work; if doesn’t probably I need a compatible siren too.
- 2305 (alarm mounting type) 00 = factory alarm 01= aftermarket
- 2306 (alarm volumetric) 00 = Yes 01 = no
- 2309 (alarm type) 00 = no alarm 01 = standard alarm 02= belgium alarm and so on
- 23D1 (anti rising function) 00=no 01 = yes
- 240E (alarm architecture) I don’t know what is
- 23B6 (presence of alarm ecu over LIN) 00 = no 01 = yes
- 23B7 (siren presence over LIN) 00 = no 01 = yes
- 2365 (thatcham mode) 00=no 01 = yes
Thank you so much @Hallahub, you helped me to enable it in my e-208 (a small typo in your message 2306 (alarm volumetric) 00 = (Yes)No 01 = (no) Yes).
I can’t change the value in 23D1 zone.
do you know if we can enable the pork assist option on e-208 ?
HiHi guys, one question, what value you have in 2309? as I don't understand what are the differences in the type of alarm.
Regards,
Hello
Can anyone help me, how to enable indexing mirrors in reverse in Arduino in BSI. Delphi 2010 EV in C5 Aircross (step by step) I turned it on in NAC but I don't know how to do it in BSI. Unfortunately, I don't know any coding.
From what i read, you need to have electric seats that have position memory.
By the way. Did your C5AC came with factory alarm?
I need dump flash for hybrid version, meaby somebody have flash.
My 9828150380 don't have hybrid option.
There is no alarm but when my car was being repaired in Serwis i got another car (peugeot 3008) it had no memory seats or alarm. And he had mirror indexing.
for DS5 YOU HAVE?1.2.1 released, fix for Wave3/4 car type, a lot of "old" cars are present inside the non-HD version (I didn't list everything, it is time wasting):
for DS5 YOU HAVE?
Hello,
Yes I do confirm,..I have configured my DS5 Hybrid with Vlud preset config
Cheers
