@infizer91 If you can share ESP81 it will be very important to us. Thanks again for what you've already shared here on the forum. I've already gotten a few things with your information.I can't do it, because don't have esp90, only esp81
smeg has been painted for a long time, and it is easier to encode it using a phone and a USB flash drive. Coding through diagnostics will not allow you to use all the functions due to *.cal.Merci pour ton super boulot l'ami grâce à toi j'ai pu me passer des services de Peugeot. Tes explications ont été super claire!!!!!, j'ai vu que tu est en train de faire un nouvelle exécutable qui ressemble à s'y méprendre à DiagBox, c'est toujours dans les tuyaux? Est-il également possible de télécoder avec un smeg+ ? j'ai essayé la manip mais j'arrive uniquement à avoir le numéro de Calibration mais ne peut pas lire le smeg et modifier les options.
Bien à toi
Nicolas
I have described most of the settings for smeg 5 here.
c5x7 = smeg 6. the principles are the same, there are more settings.For citroen c5x7 work ?
Strange im begine the fun with telecoding with analyse log files hereI don't have any logs, that's why I'm asking.
hmm@marcins Everything is clear to me with coding, but they are programmed in different ways, smeg- kwp200; nac-uds. And in both cases, the developers have moved away from the protocol specification.
@Pretto
FE->
Code:{ "Аргументы": [ { "CFG_000_FREIN_UDS_UCPR_DSG_01": { "Язык": "С косвенным обнаружением падения давления воздуха в шинах (Двигатель EP6FDTX мощностью 130 KW л.с. и нормами выбросов EURO 4 или EURO 5)", "значение": "01" }, "CFG_000_FREIN_UDS_UCPR_DSG_10": { "Язык": "с косвенным обнаружением падения давления воздуха в шинах", "значение": "10" }, "CFG_000_FREIN_UDS_UCPR_DSG_11": { "Язык": "Без косвенного обнаружения падения давления в шинах", "значение": "11" } } ], "Длинное имя": "Détection de sous-gonflage programmé", "Имя": "CFG_000_FREIN_UDS_UCPR_DSG", "Маска": "00000011", "Тип данных": "BINARY", "Язык": [ { "Имя": "Обнаружение падения давления воздуха в шинах" } ] }
68D 6AD 2E:2101:28:EEYou can use arduino.
For example;
for the line 652 752 2E:2324:04:01
1- >752:652 selecting ecu
2-> 222324 read parameter
3-> answer would be 62232400 (62->1st 23->2nd 24-3rd 00 is 4th parameter)
4-> unlock
5-> 2E232401 (2E write, 2324 address, 4th paramter as 01)
6-> and enjoy
GL
there are !!!six!!!! in esp90 different layouts of encoding pages and what suits one will not suit another. At best, poking into the blind, you will not crash in a car.@pepelxl
The other zones I already made the change (23C8 and 231D in BSI).
But I couldn't find which ESP zone I make the change you showed. Can you help me with this?
The value you already informed but I don't know which zone I make the change.
Pour savoir si Wave4 est un SD, il faut qu'il soit dans cette liste. Accessoirement tu peux regarder la NON mention "HD" sur l'étiquetteBonjour à tous et tout d'abord un grand merci à @VLud ET @bagou91 pour leurs travails extraordinaire.
J'ai réussi l'installation d'un nac wave 2 sur ma 508 phase 1 ( tout fonctionne ormis la récupération du gps dans la matrice et dans la vth pour le moment. )
J'ai l'occasion de récupérer un nac wave 4 ref 9839633680.
Mes questions sont les suivantes, quel évolution apporte le wave 4 par rapport au wave 2 ? Est t'il possible de monter le wave 4 sur ma 508 phase 1 ? Et enfin comment savoir si ce modèle de wave 4 est en SD et donc compatible avec mon écran de wave 2 ? .
Merci à tous pour votre aide et votre partage.
Manque de GPS dans le VTH : il faut activer l'af la navigation sans le nom des rues
Avantage Wave4 vs Wave2 : Plus fluide
str2 = str.Substring(10, (str.Length - 10) - 2);
strArray = new string[] { "36", &(this.calibPos % 0x100).ToString("X2"), str.Substring(4, 6), &(str2.Length / 2).ToString("X2"), str2 };
str3 = string.Concat(strArray);
this.SerialSend(str3 + this.CRC16_x25_Flipped(str3));
break;
Hi everyone,
I have (came maybe this week) Peugeot 2008. I dont have details about NAC wave version. There is no rearview camera. I want to plug and play rearview camera.
I got arduino and canbus shield also downloaded the packages. I have diagbox (many verisons with virtualbox).
Do you have part number for camera (pal or ntsc for turkey plate ?)? and installaiton manuel ?
I just need rearview not panoramic how about codes ?
Also any applicabable codes for 2008 ?
Thanks
