[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
Hi all, can someone help me please? After i upload the sketch and start the nac.exe after i click on ACCESS NAC nothing happens.
This is my log
< wdt reset
< load 0x4010f000, len 3460, room 16
< tail 4
< chksum 0xcc
< load 0x3fff20b8, len 40, room 4
< tail 4
< chksum 0xc9
< csum 0xc9
< v000448b0
< ~ld
> 00
> >764:664
> 1003
BSI N03 :)
willbe fitted into my 208Gti :)
hello can you make a tutorial how you did to integrate screen 3008 will be good for others to share your experience is sympathetic on your part I have looked for you do not leave any leak of how you did to integrate the screen I guess that you were helped for the assembly do not be selfish thanks
hello, I want to install grip control but I don't know where to connect the cables, does anyone have a diagram where to connect the cables for grip control in bsi2010ev??
posted on other forum , some dashboard cut , mounting adaptors i posted here link to thingiverse, then base part of frame designed and printed with abs and glued with oem top part frame with melted abs-acetone paste . that's all
Reactions: rafał999
Nice is 3d printing ? Are you have stl? how much cut cirroco plastic frame ?
Pièces jointes
    70.7 Ko · Affichages: 84
    81.2 Ko · Affichages: 97
Pièces jointes
    666.5 Ko · Affichages: 146
    968.3 Ko · Affichages: 136
    750.6 Ko · Affichages: 132
    701.4 Ko · Affichages: 136
    763.5 Ko · Affichages: 134
    862.1 Ko · Affichages: 137
thank you can you give me some info on telecoding the handset with diagbox and how did you manage to change the theme from the switch because I cannot change the theme on the counter thank you very much
Hello,
My VP1 is not looking too great. I think it needs a calibration or something. Beside that, the area is not loading while i’m moving around. Why is that? :(
Does anyone have a calibration for c4 cactus, please? Thanks
Mon VP1 n'a pas l'air très bien. Je pense qu'il a besoin d'une calibration ou quelque chose comme ça. En plus de cela, la zone ne se charge pas lorsque je me déplace.
Est-ce que quelqu'un a une calibration pour c4 cactus, s'il vous plaît ? Merci
Up, still trying to figure this out :(
@Albatros24 i'm already cleared but when i control it with Diagbox, all are there.
My errors are;
BSI2010_EV (2 Faults)
  • Absence of communication with the driver's seat pneumatic functions U1F83 87 ECU
  • Configuration fault (warning, this fault may be a phantom fault)
DAE_BVH2 (1 Faults)
  • U131D Fault: no communication with the parking assistance ECU
CIROCCO (1 Faults)
  • B1003 54 Fault: secure configuration faulty
Let me know how can i clear them permanently
Please make some effort, everything is written on the repo ...
Example for VF300000000000000:
Code:
>77C:67C
:DC3B:83:C0
21B0
3BB05646333030303030303030303030303030
Hello!
I've tried these exact commands and it seemed to be working.
I received the confirmation that the command was received successfully, I checked and received the correct VIN as an answer.
Unfortunately, the configuration proved to be non-persistent - after power cycle the old VIN re-appeared.
Could someone please be so kind as to help me configure this BTA3S.2 for my DS5?
Pièces jointes
    230.8 Ko · Affichages: 88
    230.8 Ko · Affichages: 80
    238.9 Ko · Affichages: 77
    341.6 Ko · Affichages: 75
    176.5 Ko · Affichages: 75
''Marc Marc'' you will get no more info about from me as you are '' un fils de .... ''
merci de me traite de fils de .... vous les anglais vous avez pourrie le forum tu as change ton compteur par respect fait un tutorial est explique
comme @VLud a fait c'est le partages des savoirs sur les forums
Vale, ya veo:benetton:
Entonces para mi solo hay 3 opciones
1: 2E210106F7FFFFFFFFFFFFFFFFFFFFFFFBFFFFFF7FFF7FFFFBFFFF EE38 BEFF
2: 2E210106F7FFFFFFFFFFFFFFFFFFFFFFFBFFFFFF7FFF7FFFFBFFFF ED38 BEFF
3: 2E210106F7FFFFFFFFFFFFFFFFFFFFFFFBFFFFFF7FFF7FFFFBFFFF EC38 BEFF
Espero estar bien ahora:vamos a ver:
Lo probaré en los próximos días.
Gracias :bien:[/CITA]
Has podido activar el grip control?
Hello!
Any ideas? @VLud maybe?
This is my log
< wdt reset
< tail 4
< chksum 0xcc
< tail 4
< chksum 0xc9
< csum 0xc9
< v000448b0
< ~ld
> 00
> >764:664
> 1003
Based on the result you are on the wrong COM port.
Also check that you are in Newline mode (next to baud rate)
If Arduino IDE is doing bad things just use Putty or YAT
Reminder: You can't use the soft and terminal at the same time.
Thank you VLUD, i needed to change arduino board(i bought another one). Now my problem is that i can use the nac.exe(i can read parameters, make changes etc.) but the serial monitor not works. if i enter >764:664 i get 000000 response
