Is all done by reverse engineering the diagbox communication with the car?
Sound harmony : enables the sound harmony choice (changes blinker sound for example). Not available on all cars. Doesn't work on my 508. But I believe it works on 308.Does anyone know what the teak places mean?
I wonder if someone could also respond
After installation of BTA module in car - to provide internal internet functionality in NAC for connected services - the connectivity menu has changed
sorry for Russian screenshots, they are not from my car, but I guess everyone get's the point
without BTA module the connectivity menu has 1-tap options for USB/WiFi/Bluetooth connectivity
After BTA module connection that screen loses functionality and looks as follows
lower menu is gone
does anyone know if it possible to bring back that menu via @VLud tool?
It seems that some settings in upper part of above mentioned menu could be configured in 2126 Telecoding_Fct_CPUSH tab
The globe icon - to check connectivity services - could be turned off by disabling "CHECK" button
I couldn't see any changes by enabling any other options here on my DS4 with Wave3
The other themes works (the 4th for exemple, without name) probably that you have only 3 themes in your nacHello today i try to add themes on me 208 with nac.
i change it on 2108 and 2127 i see now the themes. but only 3 names any help for the more themes names appearance?
Thanks
works only till reboot, after back to defaultThe other themes works (the 4th for exemple, without name) probably that you have only 3 themes in your nac
No is work only the 3 and the others not have names.works only till reboot, after back to default
Hello @hangway2 , to have the themes you must also activate them on cirocco with the tool, but you will not be able to have themes synchronized with the citroen ones, the blue cirocco theme will be linked to the orange citroen theme, the bronze cirocco theme will be linked to the red citroen theme, with all other themes the default cirocco theme will be imported
From icockpit amplify they are not real themes, they are environments and at every restart everything returns to default
Hello guys.
It's been a few weeks since i begun to "play" with my NAC and Cirocco to make them the way i wanted.
Lots of combinations, parameters, errors and hours trying to find the best configuration. I believe i'm almost "there", but i still need to solve some minor issues.
My combination is:
I own a C4L
My NAC is a Wave 2, dual LVDS, from a C4 Picasso
Cirocco speedometer, from a Peugeot 3008
I was trying to install the 180° camera from 3008 and no matter which changes i made, the image never showed up.
Today i decided to restore a backup configuration file from a 3008 that someone posted here (to be honest, i've been reading the entire topic over and over, so i don't know who posted the file) and the camera worked. I took note of ALL the parameters, restored my previous file and them started to change one parameter at a time, until i could finally understand the impact of that specific change.
However, looking for a solution to the camera, i found 2 more parameters: navigation started to work on Cirocco and the iCockpit Amplify.
I realized that the Amplify only worked through Peugeot manufacturer.
I changed the manufacturer to Citroen, the amplify kept working, but in a strange way.
If i keep the Amplify working under Citroen manufacturer, i've the following status:
- Citroen boot logo
- Themes option is missing on Settings Menu
- Amplify has just 2 options: Relax and Boost (if i am right)
there are no more theme customization options
if i choose Relax, the Cirocco changes to Gold theme and the NAC changes to Yellow theme;
if i choose Boost, the Cirocco changes to Red theme and the NAC changes to Orange theme
If i keep the Amplify working under Peugeot Manufacturer, i've the following status:
- Peugeot boot logo
the Blue theme is lost.
if i choose Relax, both Cirocco and the NAC changes to Bronze theme;
if i choose Boost, both Cirocco and the NAC changes to Bronze theme.
If the Amplify is deactivated under Peugeot Manufacturer, i've the following status:
- Peugeot boot logo
- Themes option is available on Setting Menu, with two options: Blue and Bronze (no Red theme available).
Someone found a way to keep all the 3 themes available under Peugeot brand
or
a way to make the Cirocco and NAC match their themes under Citroen brand?
I'm sharing my calibration, cirocco and NAC files.
Keep in mind that the calib file is setted to work with the C4L FMUX, so, if you are planning to restore it in another vehicle, change the 010E zone with the code that matches your vehicle.
In the end, 180° camera worked, but i still need to fix the guidance lines, as they are too high (photo attached).
And i need to fix the physical switches for ESP, Volumetric Alarm and parking sensors, as the switches aren't working since i removed the original speedometer.
After all, once again, thanks to @VLud and @bagou91 for developing such an amazing tool.
Thanks to @horuscurcino for helping me.
PS: the files are renamed as .txt because the forum returned an error message. Remove the extension before using them.
Hello . I replaced the RCC unit with NAC. Reversing camera looking down after change. What is Problem ?Hello guys.
My combination is:
I own a C4L
- Citroen boot logo
- Peugeot boot logo
- Peugeot boot logo
or
In reality, my instrument panel has always been active, I don't know why but a friend of mine also has your problem, we are investigating but we still can't find a solution, in my opinion it depends on the accessories that the donor car hadHi @RuLe
Well, at least, I’ll be able to match blue NAC and blue Cirocco and leave the red one to Amplify.
Do you remember where did you activated this green light? My NAC has the virtual switch, it works properly, but there’s no indicator on Cirocco.
Grazie
HelloHi, in 2114 section, what’s your configuration? I think you can change your menu with this (internet/intranet inactive)
