[TUTO] Télécodage et calibration d'un NAC / RCC / CIROCCO / CMB_NUM SANS Diagbox via Arduino
Awesome, you changed the brand, enabled Android Auto then reverted back to Toyota right ?
Thank's for the config !
@VLud Please, in the next version of the program, can I have an offline Parameter preview? It will be easier to get to know all the functions of the program calmly.
@VLud
My point is that this window can be opened without being connected to the car.
For example, by loading Backup before. Unfortunately, I'm not a programmer :( I don't know how to explain it exactly.
After I update firmware NAC to 21.08.25.12_NAC-r0 bug with to logo on boot go out and logo in app screen change to Peugeot :ange:
Tell me please, what for change VIN in NAC when I install used NAC from other car?
Restore the 508 config provided on the forum to have a clean start, then tweak it steps by steps.
Where can I find the theme settings. It's only blue in ProAce and it's terribly sad.
And the second thing, is it possible to activate the Video file player via USB?
There are no others themes for Toyota brand (themes are linked to the brand), you can't activate video player it is only working on DAB units.
Peugeot theme is also Blue/Black, but Citroen is Aquamarine/Orange, by changing the parameter "Manufacturer's brand" i section 2108.
What are the two options in red for? When I changed the "Default theme", I didn't notice any change.
And second: Instrument panel personalization.
I can also share configuration from RCC in Toyota Proace
211D=80
211C=F0
212D=00
210E=80
2121=00
2131=00
2126=00
2107=C0
2117=14000030
2127=0178040001030F00000000000000000600000000000000000007000000000000000000001C00000000000000
2100=0000
212F=60
212C=00
210D=00000000
2120=00
2101=00
0106=544F594F5441000000000000000000000000000000000000000000000000
2125=8034340B00
2106=00
2116=0032000000
2129=8400
211B=60B428B41EB42800
210C=0000
211F=02
2124=80
2105=0000
210A=00
2115=00
2128=40
2109=00
F190=594152564541484857475A313237313637
2119=00
211A=40
210B=00
2113=000005121F2C3946535F64
2123=C0
2104=65FE0500
2114=0000
2108=820074409056C40040
2118=4100
2112=E2
210F=20
2103=0000
F18C=3244303735303339303031333531303037363430
I have readed SW version on it:
HMI 21.616.53.17.00
iMX x0101185_171122_16.1B116
V850 W2.1_16.1S723
I try to find information for which HW version is this SW but i couldn't find clear info if its RCC A1 or A2.
Thanks
Reactions: Paride Toselli
@VLud I found your old posts
Maybe you can suggest something?
Search more inside the soft, everything you need is inside. Themes zone is not 2108. ( But again on Toyota there is only one theme )
HMI 21.616.53.17.00
V850 W2.1_16.1S723
Thanks
Answer is here
In other words change VIN not need after change calibrations? I am right?
You have to change the VIN to avoid BIP sounds ("anti-theft"), I'm not sure you understand everything you are doing on your NAC. Calibration is not modifying settings you have !
Have a clean start after calibration by restoring 508 config, changing the VIN inside the unit to yours and then tweak it to match your car, there is nothing difficult ...
@VLud OK, I will change to onther brand, but where I find themes, in which section?
By the way, will it be possible to exchange graphics using this communication in the future?
Seriously, make the effort to browse the soft a little ... 2127.
No, it is inside the firmware, the tool is only here for configuration.
In simple terms, ambiances/themes depends on which market the radio is targeted. All of them are configurable but them all are not visible or complete. Sometimes you will activate an ambiance and it will not show an icon, or menu, or will show incomplete frames.
The amount of configurable/displayable themes will also vary for each brand.
The best to do is configure each theme to your radio and share to us which one is displayed and how.
OK, I tested it. When I activated 8 theme on my Toyota profile is all blank. So it's like @VLud said.When I activate the Citroen profile and 8 theme, then 1-5 is different and 6-8 is equal to 1-3.
Generally PSA is new to me, so far I have only done in BMW and Renault. Therefore, I apologize in advance for stupid questions.
Sorry, maybe aim blind or it is something obvious for you but not for me. :)
Non of those numbers look similar to those provided under your link.
HMI 21.616.53.17.00
V850 W2.1_16.1S723
Thanks
edit
Ok, its most probably A2 because lower in this post https://www.forum-peugeot.com/Forum/threads/carplay-activable.117254/#post-2500569 obd user is sharing screen with this version on RCC A2.
So this is good news. Thanks
Because you are checking too far away, the screen you have to check is here
The last letter is determining the hardware revision (A, C, D)
Reactions: jordan87
Merci à vous pour cet excellent Tuto..
J'ai pu réaliser le montage grâce à vos explications, et ÇA MARCHE !
Je joints quelques photos.
Mon "rêve" serait de pouvoir activer le Park Assist... Et d'installer la Caméra AVANT !
A suivre...
Encore merci à VLud et Bagou91 !
Bonne route à tous.
20200923_121228_P.jpg 20200923_121250_P.jpg 20200923_155138_P.jpg 20200923_183327.jpg02_P.jpg
Reactions: VLud and bagou91
J'ai une question:
Avec cette application, serait-il possible de forcer l'écran de 12 "d'un picasso à thème smeg à être reconfiguré avec des thèmes nac?
A suivre...
Bonne route à tous.
Voir la pièce jointe 15910 Voir la pièce jointe 15911 Voir la pièce jointe 15912 Voir la pièce jointe 15914Voir la pièce jointe 15913
Super propre la réalisation du circuit imprimé :bien:
J'ai une question:
Pas vraiment car c'est lié aux messages CAN-BUS.
A suivre...
Bonne route à tous.
Bon investissement personnel dans le montage :bien:
N'hésite pas à nous partager ta config C5 :D
@VLud : "N'hésite pas à nous partager ta config C5 :D"
Ok, mais dites-moi ce qu'il faut faire...
J'ai vu ce post :
https://www.forum-peugeot.com/Forum/threads/base-de-données-des-calibrations-télématique.118960/
C'est ça ?
J'ai fait la manip. sur mon auto et 1130 ne fait RIEN ! Mais, directement 1122 donne l'info...
C5 Aircross 02/2020 (Wave 4)
Aide au stationnement AV/AR + caméra de recul - Pack Drive Assist + - Angles Morts - Sièges Chauffants - Projecteurs Full LED - Hayon Mains Libres
Calib : Réf : 0x94 0x25 0x48 -> 96 94 25 48 80
Mon Fichier de configuration :
211F=02
211D=01
F190=565237414A45485A524C4C303237323637
212D=00
210E=80
2121=00
2131=80
2126=00
2107=C0
2117=1E003AE0
2127=E07828A0030F0100000000000000040700091A1000000000001418221C0E0000000023000600000000000000
212E=00
2100=0140
2110=01
210D=EC77C030
2120=00
2101=00
2130=C0
0106=42545F434954524F454E0000000000000000000000000000000000000000
2125=0034340F00
2106=20
2116=BF38080000
2129=C030
212F=00
211B=00B428B41EB42800
210C=0010
212C=20
2124=00
2105=006C
2115=00
2128=40
2109=80
2119=00
211A=00
210B=00
210A=00
2113=180005121F2C3946535F64
2123=80
2104=66FE57B0
2133=00250000654AAE
2114=B000
2108=9A003C10905612E0010C
2118=1100
211C=F0
2112=C0
210F=10
2103=0020
F18C=3044303131313235353144344632323037393934
A+
Reactions: VLud
