it was appear when speed your's car exceeds the speed limitHi guys, how can I activate the speed symbol at the top of the display? It was initially activated in my car, but now it no longer appears, only the red triangle for danger zones remains
@RuLe 2116 [Display Speed Limit] - I think so.
@VLud
Tu avais fait pour moi un essai d'écriture dans la zone 2127 sur ton NAC, peux-tu me donner la version de son FW STP ?
Moi, j'ai : 42.01.72.32_NAC-r0 du 18/03/2020
Merci.
Ci-jointAs-tu pu faire un back-up de ton nac ? Merci
Bench sketch (power up the NAC with just 12V on PIN11&22 and Arduino on CAN-BUS lines):
https://github.com/ludwig-v/arduino...rduino-psa-telematic-diag-low-speed-bench.ino
PSA Seed / Key Algorithm and ECU Keys:
https://github.com/ludwig-v/psa-seedkey-algorithm
Decrypt NAC firmware from PSA servers and mount filesystems:
https://github.com/ludwig-v/psa-nac-firmware-reverse-engineering
Settings position inside zones:
https://github.com/ludwig-v/psa-nac-firmware-reverse-engineering/blob/main/Configuration/nac.json
Thanks James78.These are the instrument cluster dumps of the C4GP I purchased. With a simple comparison program you can identify the lines that have been modified. Does your instrument cluster come from a C4P or C4GP? In the case of a C4P could you share the extracted dump?
Hi, with the @VLud tool sure that you can convert a nac 3008 into nac c4gp, no diagbox needed, just change calibration and configuration.Hello @VLud.
One doubt, I want to put a nac with dab on a citroen c4 grand picasso but I only find peugeot 3008, ref 9820469280, can I use it by changing the encoding with this method? or will I have to use the diagbox to telecharge from psa?
Maybe not complicate myself and use a C4P nac?
thanks
Merci, ta config me semble la plus proche de mon auto !Ci-joint
Tu comptes mettre le compteur (virtual cockpit ?) de la 3008 dans ta 508 ??
Hello everyone.
Sorry for the few noobish questions. Im new to this kind of stuff.
So.
My 308 Sw (year 2018) doesnt support mirror link in default nor have build in navigation.
System version 076A.
Do I have to get new Rcc/nac and do this "hack" to enable these functions on my car?
All I would like to have in my car are carplay/AA.
Could I do this mod on my existing system?
Be gentle to noob
