Hi, can you help me please with tha park assist activation? Thank you very much
Thank you i'm pretty newbie......nac.exe is a software? AAS_UDS this can done only by diagbox? i mean i can't do this with the arduino? If you cold tell me the exact steps i would be thankful. Thank you very muchI did it exactly this way
1.NAC enabled by NAC.Exe. Zone 210C. parallel and perpendicular parking and Display touch button ..... ENABLED.
2.AAS_UDS I turned on the parking module with Diagbox 7.57. (Peugeot 308-t9)This module was not secured.
3.
DAE_BVH2:
Change A0 zone: Replace D9 with C8
>6B5:695
81
21A0
:2305:83:C0
34A00000000605C8FD000000E88A
21A0
82
4. BSI
>752:652
1003
:B4E0:03:03
2E230033
for BSI coding, I had a diagbox connected to the OBD.
Hi, i'm pretty new on this. I have ordered the arduino and the shield. Can you tell me please what are the exact steps to activate the parking assist and the auto high beam feature? Thank you
Thank you, already readedBefore they send you an Arduino, PLEASE read ALL this entire thread and another thread
https://vlud.net/nac-telecodage.html
So after i setup the arduino i need to connect the laptop with arduino trough that nac.exe software no? Thanks
Thank you, already readedSo after i setup the arduino i need to connect the laptop with arduino trough that nac.exe software no? Thanks
Anyone know how change cirocco dash, i mean (Computer, Dials, Minimum etc.) without bsi2010?
on bsi2004 buttons dont work...
Its any chance for connect button to cirocco pinout?
J'ai une petite question peut être un peu HS mais je tente quand même.
Je suis propriétaire d'un 2008 phase I de 2017 équipé d'un NAC Wave 2 avec CarPlay et caméra de recul.
Le NAC est tombé en panne, il y a 3 semaines.
Je souhaitais donc savoir si je peux acheter un Nac Wave 2 d'occasion pouvant provenir d'un autre modèle de véhicule (ex: 208, 308, 508,, etc) et l'installer dans mon véhicule.
Est ce qu'un simple télécodage via diagbox ou arduino permettra de le rendre fonctionnel dans mon véhcule ?
Bonne soirée à tous.
Thomas
Oui tu peux acheter un NAC d'occasion et l'installer sans problème, préfère fortement la méthode Arduino.
Deux points à prendre en compte: Tu ne pourras pas utiliser ton VIN pour avoir la bonne licence pour les mises à jour firmware et/ou souscrire aux services connectés > il faudra utiliser le VIN de la voiture donneuse. Tout le reste fonctionnera comme avant
Quel est le soucis de ton NAC ? Si tu penses le jeter après l'opération je suis intéressé pour le récupérer pour pièces![]()
Spróbuj zmienić frame CAN 0xA2, bit3 i bit 4. Pracuje z NAC. Coś w tym rodzaju:
jeśli (przyci1. naciśnięty) {
button1. naciśnięty = fałszywe;
CanAddress = 0xA2; // przyciski koła
CanSize = 6;
jeśli (bit3 = 0b00000000) {
bit3 = 0b00000010;
} jeszcze {
bit3 = bit3 << 1;
msg2[4] = 0x20;
msg2[3] = bit3;
jeśli (seryjny) {
Odcisk. Druk("Bit3: ");
Serial. odcisk (bit3);
sendCanMessage(CanAddress, msg2, CanSize);
} jeszcze {
msg2[4] = 0x00;
Czy rozwiązałeś problem z błędem płynów hamulcowych?
You need Arduino with two CAN interfaces. On the first just listen, on the second send modified frame.How edit frame 0xA2? can you help me?
I can read the frame. Which one do you need?im still have brake fluid error, someone with bsi2010 car can read that frame
Tank you, my question is if i can activate the auto high beam and the park assist feature only with arduino and shield or i need the diagbox too? Thank youBefore they send you an Arduino, PLEASE read ALL this entire thread and another thread
https://vlud.net/nac-telecoding.html
I believe so, but unfortunately I cannot help you. I had this factory settingTank you, my question is if i can activate the auto high beam and the park assist feature only with arduino and shield or i need the diagbox too? Thank you
i understand...as if I read that you was able to activate on your car. Thank you anyway.I believe so, but unfortunately I cannot help you. I had this factory setting
I only activated PARK ASSIST, I want to activate visiopark 2 and an opening trunk and indexed mirrors, but so far no cheap spare parts. My version is C-series with add-onsi understand...as if I read that you was able to activate on your car. Thank you anyway.
I understand. SO can you help me please with park assist activation tutorial? Thank you very muchI only activated PARK ASSIST, I want to activate visiopark 2 and an opening trunk and indexed mirrors, but so far no cheap spare parts. My version is C-series with add-ons
> 00
> >764:664
> 1003
< OK
> 00
> >75F:65F
> 1003
< OK
Thank you i already saved your post, unfortunatley i didn't understand where i cand find the "DAE_BVH2: Modify Zone A0: Replace DD by CC"Hi, i just purchased a second hand C5 Aircross with 12 sensors, automati gear, and camera. Can you please help me with Auto park assist activation? I'm new in this, i already ordered the arduino, can bus shield and cable(waiting for delivery). Can you help me with the coding please? Thank you very much. My email:[email protected]
I mean, i dont' understand this "Pour le Check Sum, On prend TOUT : 34A00000000605CCFD000000
if you receiveI mean, i dont' understand this "Pour le Check Sum, On prend TOUT : 34A00000000605CCFD000000
et on calcule un CRC-16/X-25, puis on échange les 2 octets..."
What &where i need to modify this?
Thank you
Hello from austria
I´m owner of an 2018 Peugeot 3008 (P84) and wanted to upgrade from Wave2 to Wave4 with DAB. I know that it never was mounted in this car !!
I've done the following:
In generall it's working but there are somy annoying issues:
- uploaded originale Wave2 configuration (3008-9693621880.cal) with VLUD's tool (Thanks al lot for your great work at this point !!!
- corrected the concerning paramaters and screen settings in the Wave3-Zone
- Te pictures of the car are from 308-> I understand that the ID's in Zone 2108 are different between W2 and W4. I've selected the W2 3008 in configuration-> but the 308 is displayed
- the PDC an camera Isn't working correctly.
I'm sure it's a problem with the calibration !!!
- If i put in reverse gear, camera goes into "Zoom-Mode" because of "Red-Alert" from PDC -> It' just a display Issue cause the PDC is working correctly (Audio-signal is OK)
- the colours of the camera are wrong
- without camera (driving forward) to an abstacle the PDC switches to car Picture but no display of any distance lines (only correct beeping)
Perhaps someone can help me !?
best regards in advance![]()
