Hi again!
My progress so far.
I noticed that as soon as:
1. I upload the sketch via Arduino IDE
2. Go to PSA -Arduino-NAC/RCC interface
3. Arduino Connect
4. Read Parameters
5. Parameters
I am able to access and telecode if I am very fast.
I managed to change the VIN and configure park assistance (now radio works without beep-beep ;) )
But if I spend too much time configuring and then Save
The communication seems "hang up" the progress bar on the application just fills till middle, or don't fill at all and just sits there.
Could it be that I need to change some of these in order to work properly?
For example max data length
or can speed
or can rcv buffer
or can default delay ?
#define SKETCH_VERSION "1.6"
#define CAN_RCV_BUFFER 40
#define CAN_DEFAULT_DELAY 5 // Delay between multiframes
#define MAX_DATA_LENGTH 512
#define CS_PIN_CAN0 10
#define SERIAL_SPEED 115200
#define CAN_SPEED CAN_500KBPS // Diagnostic CAN bus - High Speed
#define CAN_FREQ MCP_16MHZ // Switch to 8MHZ if you have a 8Mhz module
Hi, can you tell me which steps you do to activated park assistance? Thank you!
Hi,
I have a Peugeot 508 Break (R8) from 2019.
I have installed the original alarm (ultrasonic module, button/push button and siren).
With Diagbox I cannot activate without having access to psa servers
Is it possible to activate it with Arduino?
How could I do it?
Can you tell me the parameters?
Thank you
Hello everiyone, I hope someone can help me. I am changing the rotary lever of my Peugeot Rifter for a Peugeot 5008 impulse lever.
I am making the following settings.
>6A9:689 AXN8
1003
222101
62210104FFFFFFFFFBFDFEFF
:4854:03:03
2E210104FFFFFFFFF7FDFEFF
222101
62210104FFFFFFFFF7FDFEFF
1001
>752:652 2010EV
1003
22D545
62D54500
:B4E0:03:03
2ED54501
2E2901FD000000010101
22D545
62D54501
1001
Although the impulse lever turns on and performs part of the functions, it does not finish making the changes because the transmission control unit continues to detect that the rotary control is not connected and generates several errors. My question is, am I missing some coding to do so that the transmission control unit does not tell me that the rotary control is missing when the impulsive control is already configured and connected?
Hello Everyone. First of all thanks to Vlud for this amazing work and research.
I've been trying to follow the thread as well as I can although sometimes with the translators is hard to understand some stuff.
I have a C4 Lounge, which is similar to C4B7 and C4L as far as I understand. I've successfully installed Cirocco cluster thanks to this thread and now I want to install NAC to replace my SMEG6. I got a NAC W4 HD from DS3 Crossback and the quadlock adapters and managed to get it working, but somehow the physical buttons to enter de menus dont work, so I'm stuck in the "profiles" menu. I have tried different calibrations and parameters files but, it only gets worse as I can end up with black screen or washed screen. Now I've applied 3008_RESTYLED which I know it has physical buttons, but those still wont work. Sterring wheel buttons do work correctly as well as physical AC controls.
When going back to SMEG6 all buttons do work correctly so I believe this is either a NAC configuration or a DiagBox config. BUT if the buttons work with the SMEG, then I'm assuming its OK in DiagBox, therefore This should be something in the NAC unit.
Has this happened to anyone? I would really appreciate some guidance as I believe that just trying to blindly flash calibrations wont do the trick here.
Thanks in advance!
Hi! Many thanks to Vlud for his incredibile work and by sharing with everyone.
Does anyone know if a Wave 4 HD unit is able to work/coded with a 7 inch continental DGT7C screen(SD)? Mine is still on the way, so I can’t test this:)
@Jlozde Sorry to reply to an old post, I'm trying to use "trunk from remote" by coding zone 2354 to 04, as is stated in your file "trunk from remote.txt" , coding succeeded. Also when I read zone 2354 it shows parameter is set to 04.
I see the car does not turn on the lights anymore when pressing third button, but also the trunk does not unlock. Do you know what could cause the problem? I would expect the trunk to unlock when pressing the third button.
@mach1
Il utilise un autre logiciel...
Pour : 652 752 2E:2324:04:00
Je pense que ça se traduit par :
Débloquer le calculateur par >752:652 (C'est inversé !)
Lire la Zone 2324 par : 222324 -> AABBCCDDEEFFGG....
Remplacez ensuite le 4ème octet par 00 et Écrire la Zone
2E2324AABBCC00EEFFGG.....
A tester !
Reactions: Nike.g
7F2737 Unlocking - Required time delay not expired.
What does this error really mean? Do I have to wait a while to write or is the drive locked and I have to wait for it to unlock?
@mach1
A tester !
I think the fourth bit is also counting the area to be written because in some examples that this user published, it tells you to change bit 27 and 28 and if it is not counted from the beginning including the area, those bits do not exist, so I think it is really interpreted like this: 2E2324 01, 02, 03, 04 according to the zone option
and 2E23AE 01, which activates these zones.
For example, in zone 23AE only the values 00 or 01 exist.
So the interpretation would be
2E:2324:04:00
2E-Zone writing
2324-Zone
04-Number of bits to change counting the zone
00-Value of the bit to write
  • The value 04 does not exist.
    2354 Function of the third button of the high-frequency remote control
    Parameters:
    00 Opening or unlocking door 5
    01 Opening or unlocking the rear window
    02 Lighting/alarm
    06 Unlocking the cargo area
    07 Opening/closing the right sliding side door
  • >752:652
    1003
    222354
    :B4E0:03:03
    2E235400
    1001
    With this we configure the third button for the opening of door 5
Reactions: FrankZZ
    Parameters:
    02 Lighting/alarm
  • >752:652
    1003
    222354
    :B4E0:03:03
    2E235400
    1001
Thank you very much, I will try this. Where did you find the description of the parameters? I could only find the zones list of bsi/nac in github. Parameter description is very valuable
I am also curious if I can disable start/stop in bsi with zone 23BB "Start stop presence and type"
