Hello.
And how to reset the mileage in CMB_NUM. Did not see on the board nand.
Pièces jointes
    321.8 Ko · Affichages: 74
Ciao a tutti, qualcuno ha questo software SQLite NAC Peugeot, grazie.
sgaaageto-a-1920-jpg.27952
Pièces jointes
    230.3 Ko · Affichages: 806
Thanks, now I cant read 240E, I get 7F2231. why it could be? I tried being fast, with engine off/on
i appreciate if you can help me
so, the issue was that volumetric module didn't have power, the data cable was factory mounted but not power. add it and worked, no need to seet the 240E
Hello, I turned on mirror indexing in the BSI reverse gear, but unfortunately it does not work. Do they have to be mirrors that have this option or do I need to program something else?
Pièces jointes
    885.8 Ko · Affichages: 147
    171.9 Ko · Affichages: 144
    166.3 Ko · Affichages: 146
Does anyone know why I can't change the system theme to Toyota? I can easily switch between Peugeot and Citroen, but when I select Toyota and enter number 4 in the default theme (section 2108) it displays the word ambiance not configured
hello. I am trying to install a simple camera to my C4 Cactus 2018. I bought the following adapter:
https://ae01.alicdn.com/kf/H2d0ffb3...2008-3008-5008-C4-C5-Cactus.jpg_Q90.jpg_.webp
and a normal camera. Do you know any possible way in which i can activate the camera without buying a diagbox kit that is very expensive or going to the dealership? Also when i opened up to see the module, i saw that in the harness, the module A already had wiring for pins 16 and 17. I saw somewhere that not all the time it's required to code the BSI to see the camera. Is that true? Thanks
Somebody in this forum told that it is works only if you have seat memory function in your car.
Bonjour;
suite à un remplacement d'un Nac Wave 1 sur Expert vers un Wave4; j'ai refait intégralement la config (l'export du Wave1 vers le 04 n'a pas fonctionné).
Le NAC provenait d'un autre modèle de véhicule, avec envoi de la calibration du Proace Wave4.
Tout les onglets du Soft PSA-Arduino-NAC (un grand merci à VLUD et Bagou91) ont été remis à l'identique.
Le seul souci restant , est la qualité de la vidéo de la caméra 180°.
l'écran est rosé et surtout, je ne vois plus l'attache remorque lors des manœuvres d'attelage.
Je vous glisse la config de l'onglet 212A du Visiopark pour l'Expert récupérer du Wave1.
si quelqu'un a des captures de ça config sur un wave3 ou 4 pour un Expert; Jumpy; Proace; je suis preneur.
J'ai également testé de modifier les valeurs de façon empirique les valeurs de l'onglets 212A ; mais après chaque reboot du NAC, les valeurs sont bien prise en compte; mais l'image reste identique.
Je sèche; merci pour toutes idées.
2022-09-01 18_46_26-C__Users_jbataller_OneDrive_Peugeot_308 II_NAC.png 2022-09-01 18_46_37-C__Users_jbataller_OneDrive_Peugeot_308 II_NAC.png 2022-09-01 18_51_50-C__Users_jbataller_OneDrive_Peugeot_308 II_NAC.png 2022-09-01 18_51_58-C__Users_jbataller_OneDrive_Peugeot_308 II_NAC.png capture rendu1.jpg capture rendu2.jpg capture rendu3.jpg
A+
Ce ne serait pas une histoire de type de vidéo PAL / NTSC... de la caméra ?
hello,
C'est effectivement une bonne idée, mais il s'agit de la cam d'origine; et il ne me semble pas avoir vu se genre de réglages dans tout les onglets de l'application.
je rejette un coup d'oeil ce WE pour vérifier.
