Voici les étapes que j'ai identifiées
- acheter des tiges d'extraction : fait -> Norauto
- commander un cable USB pour RT4 : fait -> concession Peugeot (ref 6574JH : demander à chercher dans les pièces/accessoires pour un véhicule autre que la 807 - ex 607 - , qui n'a a pas ce faisceau de base ... il s'agit de l'ajout d'une nouvelle pièce)
- commander un CD de Firmware : fait -> concession Peugeot (ref 9679242580)
- acheter un DD de remplacement : mais lequel ? et où ?
Hitachi Endurastar J4K30 ?
Toshiba MK3029GAC ?
HGST Endurastar J4K100 ?
https://www.darty.com/nav/achat/inf...e_ata_pata_pour_pc_portable__MK790317262.html
ce dernier semble pouvoir convenir (vu sur site RS)
https://fr.rs-online.com/web/p/disques-durs-internes/8047827/
https://docs-emea.rs-online.com/webdocs/12f4/0900766b812f4ffc.pdf
"Large Capacity, Robust Features for Extreme Environments
HGST delivers an industry-leading 100GB capacity in its latest Endurastar line of 2.5-inch
hard drives designed especially for extreme environments. The Endurstar J4K100 and
N4K100 models provide twice the capacity of their predecessors and are built to operate
at altitudes of up to 5500 meters. The Endurastar J4K100 is designed for the most severe
conditions, with an operating temperature range of -30ºC to +85ºC. For milder conditions,
the Endurastar N4K100 provides an operating temperature range of -20ºC to +75ºC. The
drives are offered in SATA and PATA interface options for design configuration flexibility.
Right Choice for the Road
Endurastar hard drives are built to meet the rigors of the automotive environment, including
navigation,telematics, in-car entertainment and vehicle relational management. The drives
have been designed using a proven 5th generation platform."
- ou acheter un SSD et un boitier IDE/mSata :
http://www.theobouzige.fr/archives/4633
- suivre le tuto Caradisiac :
http://forum-auto.caradisiac.com/marques/citroen/sujet44135.htm
- cloner le DD d'origine vers le nouveau (s'il est encore "lisible" ...)
- ou laisser le RT4 initialiser le nouveau HDD ? je ne sais pas encore .....
- reconfigurer le VIN dans le RT4 ? avec les scripts Mira ? il faut que je creuse ....
Je communiquerai au fur et à mesure ...
