Does anyone have e-2008 or e-208 with park assist coded? If yes, could you please share the reading of DAE zone? Tks a lot!
211D=08
211C=F0
212D=00
210E=8E
2121=00
2131=80
2126=40
2107=C0
2117=1E003A60
2127=FF7800200103050A080000000000061000000000000000000000000000000000000000000000000000000000
212A=0EF40BF30320070801E7070802C8026C065402560804020608028028021F0001FA0063646400006464
2100=0740
212F=48
2110=00
210D=D463C010
2120=00
2101=00
2130=C0
0106=434954524F454E0000000000000000000000000000000000000000000000
2125=8434340D20
2106=00
2116=BB30080200
2129=C010
211B=E0B428B428B42800
210C=C010
211F=02
F18C=3044303130383134343144344545363733444338
2124=80
2105=0010
210A=00
2115=82
2128=40
2109=04
F190=564637334135475A54474A363332343133
2119=98
211A=40
212E=00
210B=80
2113=280005121F2C3946535F64
2123=80
2104=04FE1480
212C=20
2114=B000
2108=020036101056EE0008
2118=5000
2112=70
210F=18
2103=0800
2132=0000
@marcins,Your's esp key ABFB
Good evening, I used your method And also your attached file for 3008, But the Park assist of not work for me, even though I have 12 sensors, In the attached pictures, what I worked on, I started withHave you been able to activate any other features?
Good evening, thanks for the work I did your method and the attached file for the 3008 car, but unfortunately the park-assist not work, I have t button in screen, but when I click on it it does not work.Have you been able to activate any other features?
hi. you can send the last program pepelxl please . i dont found in githubThe only thing I found makes no sense. For example I enabled HBA with 04B8FD, but if I translate it in binary (1011 1000 -B8 1111 1101 -FD) and compare it to this ressource from Pepelxl :
Then we can see that HBA should be disabled (0)... but in reality it works! and HBA is not the only thing that does not make sense. pretty much everything does not match the hex.
Am I stupid ? What am I missing ? How can I know if 04B8FD has ACC or not?
Good evening, I have a question PSA Coder Yes Arduino, when it is used for encoding or reading only...
Hello everyone,Does anyone know the answer?
My 5008 II GT 2019 does not have a front camera, only a rear camera.
I want to install a front camera and now I have a question.
To buy:
- 9820438080 - front bumper harness for 6PDC + Camera + 2 halogen lights
- 9809301080 - front camera
- 1617977480 - rear camera mount
- 1617977380 - front camera mount
- 9818608380 - VisioPArk 2 controller
I almost have everything!
Now the question?
The connector for the VisioPark 2 controller is already installed in the car, next to the glove compartment.
Voir la pièce jointe 35508 Voir la pièce jointe 35510Voir la pièce jointe 35509
Scheme to VisioPark 2:
- 7533 - rear camera
- 7532 - front camera
- 7531 - VisioPark controller
Scheme to only rear camera:
- 7533 - rear camera is now connected to the NAC radio
Version only with rear camera
7533 rear camera:
PIN 2 -> PIN 17 NAC 8480
PIN 3 -> PIN 16 NAC 8480
Version with VisioPark 2 7531
7533 rear camera:
PIN 2 -> PIN 12 VisioPark 2 7531
PIN 3 -> PIN 3 VisioPark 2 7531
7531 VisioPark 2:
PIN 15 -> PIN 17 NAC 8480
PIN 6 -> PIN 16 NAC 8480
Do I need to modify something (change PINs in NAC) once the harness is in the car? Just connect the front camera and VisioPark 2 to the plug and do the coding?
hi, this App work with Arduino er daigbox...i think only reading . i have only beta. i wait lastest program
ok thx. it is open source ?hi, this App work with Arduino er daigbox...
¿Puedes enviármelo también, por favor?hi. puedes enviar el último programa pepelxl por favor . no me encontré en github
je n'ai rien reçu malheureusement¿Puedes enviármelo también, por favor?
Il faudrait déjà savoir de quelle "radio" tu parles et également, quelle configuration tu veux modifier....Bonjour à tous, j'ai essayé de configurer la radio avec diagbox mais je reçois un message dans diagbox indiquant qu'il n'y a pas de dialogue avec le ECU. Grâce à cette méthode pourrai-je configurer ma radio ? Merci beaucoup.
Bonjour, ma radio est une Continental AIO NAC B1CEM 00, Quand j'ai essayé de le faire avec diagbox, le message que j'ai reçu disait "pas de dialogue"Il faudrait déjà savoir de quelle "radio" tu parles et également, quelle configuration tu veux modifier....
Et tu veux y modifier quoi?Bonjour, ma radio est une Continental AIO NAC B1CEM 00, Quand j'ai essayé de le faire avec diagbox, le message que j'ai reçu disait "pas de dialogue"
merci.
Je souhaite activer Bluetooth, Apple Carplay et Mirrorlink, ma question est la suivante : si je ne peux pas utiliser digabox avec ce projet Arduino, puis-je l'activer ? Merci de votre réponseEt tu veux y modifier quoi?
Eh bien, merci beaucoup, je vais l'essayer avec le projet Arduino, j'apprécie vraiment votre temps. Merci beaucoup.Oui, avec Arduino et le soft développé par @VLud tu pourras paramétrer ce que que tu veux dans le NAC (via la prise ODB)
Pour autant, je suis surpris que les options que tu cites ne le soient pas d'origine
Et Mirror Link tu ne pourras pas, il est remplacé par Android Auto
