Mój numer ESP 98 266 943 80Podaj numer identyfikacyjny ESP.
My ESP number 98 266 943 80
As a consequence, I would like to install ACC radar in the 3008, these options are locked from the DIAGBOX level
P.S. How to turn on PM?
Try Send me PMMój numer ESP 98 266 943 80
Hello! how are you, I am new to the forum. I would like to ask if all the functions of PSA Arduino are available in Diagbox? if I get the original equipment I can modify values in a 10 inch Wave4 like:
Add touch menu to the screen
Remove the car showing sensors when reversing and see the camera bigger.
Will this be possible with diagBox?
Thank You Very much.Try Send me PM
I'll check tomorrow. If the ESP is 28 byte then there is no problem. If 38 then not yet. You could come to me. I live 80 km on east of you
Hi wonder if someone could help me on what program i use for to code SMEG 2016 308 T9 am looking to add radio text and parking info to the matrix screen. i have tried CIROCCO when i press CMB access it lets me backup the parameters then if i press parameters it fails and crashes.
Actually, this amplifier is not Focal, but PSS=Denon. However it is Gen 3 and it requires special connection by 8 wires from main unit to amplifier.Focal amplifier 9825899680 is GEN1 or GEN3?
Hello, I am looking for CONFIGURATION file for NAC (best not HD) for 2008 or 3008 or 508 with Focal system.
Hi, thank youHi, This is my configuration NAC from DS7 with Focal.
Hello, I'm new to this, and I would like to know if activating adaptive cruise control would work on my 208. I don't know if I have enough sensors for it to work though. I have safety pack, so I have a front sensor that can compute distance between front car and mine in order to use emergency braking. Do you guys have any idea ? Thank you in advance.
Salut, je suis nouveau et je voudrais savoir s'il était possible d'activer le régulateur de vitesse adaptatif sur ma 208, Même si je ne sais pas si je possède assez de capteurs pour le faire fonctionner. J'ai le safety pack, donc j'ai un capteur avant qui peut calculer la distance entre ma voiture et celle de devant pour faire fonctionner le freinage d'urgence. Est-ce que quelqu'un aurait une idée ?
Grand merci par avance !
merci beaucoupIl faut télécoder le BSI pour que la caméra 130° fonctionne le sujet a déjà été abordé
Good evening,
It is also necessary to modify the AAS and DAE calculators!
