I have problems with front right (driver) speaker on 508 which makes buzzing sound sometimes. There was no problem with the SMEG. At first I thought it is because I have made my own wiring converting SMEG> NAC. Now that my Chinese converter arrived and I replaced it but the bad speaker is here again. (I even experience some problems with the rear view camera, probably the cable is bad too). Could it be something I need to tweak in terms of settings / telecoding, or just my speaker probably is broken?
The 508 is with regular sound system + CD (no JBL etc.)
My second problem is with the parking lanes. Back on the SMEG, the side lanes were perfectly reflecting the width of the car.
Now the SMEG seems to show that the car is wider, like 10 cm more on both sides, can this be adjusted?
EDIT:
One curious question. It seems my donor card Citroen C3 Aircross, is coming with the free "Real time traffic service". I have created account, enabled the service (it wasn't claimed for that VIN). So now I have active service to 2024. The thing is, if I change the VIN of the NAC to this C3 VIN, should I be able to activate the live traffic, then go and return to my current VIN of my 508, so it won't beep non-stop?
The thing I am struggling now is that I cannot try the above scenario, as seems my NAC does not want to connect to WI-FI due to some reason. It used to be OK and was connecting just before my attempt to change to C3 VIN. Now no matter which VIN I use, Wi-Fi only says connecting> Internet connection lost ....
EDIT2:
Is there a way, to make my outside temperature be showing nonstop, even when android auto is enabled?
